darth
#1 Posted : Sunday, August 11, 2013 7:59:29 AM(UTC)
darth
I found that my compressor was low on r134 (negative pressure). After searching the internet for the correct pressure, I found all kinds of pressures, ranging from 55psi (I finally decided was for automotive or a/c, even though claimed to be for a refrigerator) to a more reasonable 3 to 5 psi. As my compressor was made by Whirlpool, one pundit said it should be on the lower number, ie 3psi.
I have used this number, but my technical information manual, says 0psi. Experimentation seems to indicate 0psi doesn't cool very good, so I am using 3psi, which gives me a little frost on the suction line (can't see any frost on the evaporator).
My unit now cools to freezer 0 degrees and refrigerator 40 degrees, but requires the control to be turned up (cooler) higher than in the past. Could the compressor also be weak?
#2 Posted : Monday, August 12, 2013 3:19:20 AM(UTC)
If you get frost up to the compressor, the system is over charged.
If your low side pressure was not below -20 pounds, you have a bad compressor. Fridg. will run a lot and waste power.
darth
#3 Posted : Monday, August 19, 2013 12:03:06 PM(UTC)
darth
Even 2psi frosts the tube to the compressor. I'll try lowering to 1psi.
Marat
#4 Posted : Thursday, January 23, 2014 10:21:11 AM(UTC)
Marat
#5 Posted : Saturday, February 1, 2014 8:49:33 AM(UTC)
If you have heavy frost in the freezer coils, the system will run too cold and the R134A vs temp chart will indicate a lower pressure, best to clean coils first.
