unit will cycle pass the wash and drain cycle, about 1/2 way of the cycle rotation and stops. machine continues to run but will not proceed further. If I manually rotate knob 2-3 clicks it will complete the cycle on its own. I have cleaned the water pump and check valve, water inside cabinet is steaming hot when I open the door.
Sounds like you have a sticky or malfunctioning timer or a bad connection at the timer...take cover off and check your connection leading to it and it's terminal for debris or corrosion clean if necessary, reattach and test.......your model number was incomplete so i don't have a part number for you.
Originally Posted by: HumboldtRepairMan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Sounds like you have a sticky or malfunctioning timer or a bad connection at the timer...take cover off and check your connection leading to it and it's terminal for debris or corrosion clean if necessary, reattach and test.......your model number was incomplete so i don't have a part number for you. After checking model # here is the complete: SHU3036 UC U/12
Originally Posted by: rappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) unit will cycle pass the wash and drain cycle, about 1/2 way of the cycle rotation and stops. machine continues to run but will not proceed further. If I manually rotate knob 2-3 clicks it will complete the cycle on its own. I have cleaned the water pump and check valve, water inside cabinet is steaming hot when I open the door. model # shu3036uc u/12
