rappy
#1 Posted : Sunday, August 11, 2013 10:37:11 AM(UTC)
rappy
unit will cycle pass the wash and drain cycle, about 1/2 way of the cycle rotation and stops. machine continues to run but will not proceed further. If I manually rotate knob 2-3 clicks it will complete the cycle on its own. I have cleaned the water pump and check valve, water inside cabinet is steaming hot when I open the door.
HumboldtRepairMan
#2 Posted : Sunday, August 11, 2013 10:56:56 AM(UTC)
HumboldtRepairMan
Sounds like you have a sticky or malfunctioning timer or a bad connection at the timer...take cover off and check your connection leading to it and it's terminal for debris or corrosion clean if necessary, reattach and test.......your model number was incomplete so i don't have a part number for you.
rappy
#3 Posted : Sunday, August 11, 2013 11:05:06 AM(UTC)
rappy
After checking model # here is the complete: SHU3036 UC U/12
HumboldtRepairMan
#4 Posted : Sunday, August 11, 2013 11:08:48 AM(UTC)
HumboldtRepairMan
Here's your schematic on your touchpad breakdown and part numbers
01-Fascia Panel parts for Bosch SHU3036 UC/12 (FD 8003-) - AppliancePartsPros.com
rappy
#5 Posted : Sunday, August 11, 2013 12:11:04 PM(UTC)
rappy
model # shu3036uc u/12
