jpippin
#1 Posted : Friday, August 2, 2013 4:21:00 PM(UTC)
jpippin
My freezer will not cool. It only blows hot air. I have checked and replaced the start capacitor, and the thermostat. I have checked the defrost switch, cooling switch, and it still does not cool. I have not checked the freon as it is a sealed system. What could be the problem?:)
#2 Posted : Wednesday, August 7, 2013 3:27:22 AM(UTC)
Is the compressor running?
You can usually hear it but should also be able to feel it vibrating.
I am assuming that since you said it blows hot air that the evaporator fan is running.
If the compressor is running then you have a sealed system problem.
This will be an expensive repair as you need a pro. Usually it makes more sense to put the dollars towards a new unit.
jpippin
#3 Posted : Wednesday, August 7, 2013 3:42:29 AM(UTC)
jpippin
Hi Denman,
Thanks for your post. That's what I was afraid it would be, and yes the evaporator fan is running. Thanks for your help!:)
Upright Frigidaire freezer not cooling right! (Refrigerator & Freezer Repair)
by rebeccagalligan 11/9/2014 11:41:41 AM(UTC)
Frigidaire Freezer not cooling (Refrigerator & Freezer Repair)
by Ken TN 4/27/2008 6:36:20 PM(UTC)
