My freezer will not cool. It only blows hot air. I have checked and replaced the start capacitor, and the thermostat. I have checked the defrost switch, cooling switch, and it still does not cool. I have not checked the freon as it is a sealed system. What could be the problem?:)
Is the compressor running? You can usually hear it but should also be able to feel it vibrating.
I am assuming that since you said it blows hot air that the evaporator fan is running.
If the compressor is running then you have a sealed system problem. This will be an expensive repair as you need a pro. Usually it makes more sense to put the dollars towards a new unit. |
THIS FORUM IS DEAD!!!!!!! |
Hi Denman, Thanks for your post. That's what I was afraid it would be, and yes the evaporator fan is running. Thanks for your help!:)
