I am trying to fix our gas dryer because it is working but is not heating. Tried to open it and there was no flame, and I noticed the igniter to be broken. I then replaced the igniter still no flame. What would be the problem? Hope you can help me
Find your tech sheet usually under the console or underneath the lid........test all circuitry to do with heating........The thermal fuse.....hi low thermostat/thermister.....all thermostats on burn tube and blower housing doing a continuity test on it all........try a you tube video on how to do this.....good luck
thank you. dryer is working.
