2 Pages12>
yanks21
#1 Posted : Monday, July 29, 2013 5:04:46 AM(UTC)
yanks21
Hi All,
New to this forum, perhaps you can help me. I messed up. I had an ice plug in the drain, and in the process of cleaning it up, and cleaning the coils, I shorted out the freezer blower fan. Evidently I pulled a wire loose from the motor, and it arced against the panel. (DUMB!) I ordered a new fan motor, but now only the light comes on. The compressor wont run, and the coils wont frost. Is there a fuse somewhere?
Thanks!
#2 Posted : Monday, July 29, 2013 5:40:45 AM(UTC)
I went to the Sears site but cannot seem to get into the parts sections.
Looks like your unit uses an adaptive defrost board.
Could be you blew the board.
Also how long have you waited?
Give it at least half an hour as you may be in a defrost cycle but it should finish in half an hour or so.
Also make sure that the main thermostat is not set at Off.
[COLOR="Blue"]Is there a fuse somewhere? [/COLOR]
No
Part number: AP3211551
yanks21
#3 Posted : Monday, July 29, 2013 6:38:57 AM(UTC)
yanks21
It was turned up all the way. I waited a few hours now. It is not showing any cold whatsoever. Do you think it is the board or a thermostat?
yanks21
#4 Posted : Monday, July 29, 2013 7:00:05 AM(UTC)
yanks21
Denman,
It was turned up all the way. I waited a few hours now. It is not showing any cold whatsoever. Do you think it is the board or a thermostat? How do I test/diagnose? I really don't want to spend more $ than I have to.
#5 Posted : Monday, July 29, 2013 9:00:58 AM(UTC)
I think this unit uses a analogue (old style) thermostat so you could short across it's connections and see if it fires up.
If not then I would put my money on the defrost board.
OR measure the voltage across the thermostat's contacts. It should be 0 volts.
yanks21
#6 Posted : Monday, July 29, 2013 9:08:00 AM(UTC)
yanks21
Thanks, will do.
Is that the defrost thermostat in the freezer compartment?
#7 Posted : Monday, July 29, 2013 11:38:26 AM(UTC)
No.
The main thermostat in the control console.
yanks21
#8 Posted : Tuesday, July 30, 2013 4:37:01 AM(UTC)
yanks21
This one? I imagine I will be checking across the red sand black wires?
UserPostedImage
#9 Posted : Tuesday, July 30, 2013 5:04:43 AM(UTC)
Sorry but your lin k did not get through.
Click on the picture for more info.
Part number: AP2151609
yanks21
#10 Posted : Tuesday, July 30, 2013 5:44:57 AM(UTC)
yanks21
Yep That one!
I messed up! (Dryer Repair)
by David Dukes 10/10/2013 7:24:03 AM(UTC)
2 Pages12>
