willie2840
#1 Posted : Saturday, July 20, 2013 1:40:26 PM(UTC)
willie2840
I have removed the Monarch garbage disposal but cannot remove the flange that is in the sink it is the type with threads that threads into another flange the 2 parts are rusted together and loose from the sink which means that I have to hold 1 part and try to turn the other part s there a special tool to separate these 2 parts.
scott5495
#2 Posted : Sunday, July 21, 2013 10:10:10 AM(UTC)
scott5495
there is no special wrench for this.
the large nut on the bottom of the sink that holds the flange in, is a flunky metal.
you will have to chisel it to break apart.
willie2840
#3 Posted : Sunday, July 21, 2013 11:28:34 AM(UTC)
willie2840
I was able to break it apart from the top using needle nose pliers
it was made out of plastic pretty easy to break.
Roman77
#4 Posted : Thursday, March 26, 2015 11:52:17 PM(UTC)
Roman77
This is exceptionally pleasant and better than average post..spanish programs - how to learn spanish
..You shook posting it....Thanks a considerable measure for posting it....!!!
Guest (4)
