pcntexas
#1 Posted : Monday, December 10, 2007 11:31:41 AM(UTC)
pcntexas
I cannot get this bolt to budge. I'm using a 7/16 socket which is the correct size - so is counter clockwise the correct direction? I sure don't want to round those corners on the bolt head...I'd really be "up a creek, etc..."
:confused:
#2 Posted : Monday, December 10, 2007 5:00:45 PM(UTC)
Yes, the 7/16" is the right size and the CCW is the right direction.
pcntexas
#3 Posted : Monday, December 10, 2007 6:05:58 PM(UTC)
pcntexas
Hey, thanks for the help Gene! But, why can't' I get the bolt to budge? I know there's a rubber washer, but I can't make any headway. Any suggestions? Could the fact that I'm using the hinged extension bar have anything to do with it?
#4 Posted : Monday, December 10, 2007 6:21:47 PM(UTC)
Make sure the socket is pretty tight on the screw head, grab the bottom part of the agitator with one hand and force the screw out. You can try a WD-40 first.
