civictuner95
#1 Posted : Wednesday, July 10, 2013 4:16:20 AM(UTC)
civictuner95
I have a Kenmore Extra Large capacity washer that refuses to engage the final spin cycle which also won't drain the water in the tub. I just replaced the lid switch and still no go. When the previous switch went bad it did short which tripped the breaker.
Is there another safety switch or other device that would keep the spin cycle from engaging? I tried selecting the spin cycle under the difference wash option and it's the same issue. No power at all. All washing cycles work fine, agitator functions properly.
Any advise or insight would be much appreciated! Thanks!
fairbank56
#2 Posted : Wednesday, July 10, 2013 5:22:24 AM(UTC)
fairbank56
Groups: Expert
With washer in spin mode, if the timer does not advance on it's own, it's either the lid switch (or lid switch operation), timer or faulty wiring between lid switch and timer.
Whirlpool 3951166 Timer - AppliancePartsPros.com
Whirlpool 3949238 Lid Switch Assembly - AppliancePartsPros.com
Eric
civictuner95
#3 Posted : Wednesday, July 10, 2013 2:11:54 PM(UTC)
civictuner95
Okay, so even if the spin cycle does not engage the dial should still be progressing regardless?
fairbank56
#4 Posted : Wednesday, July 10, 2013 2:50:39 PM(UTC)
fairbank56
Groups: Expert
Yes, when in spin mode, a single contact in the timer applies power to the timer motor and to other contacts in the timer for applying power to the drive motor. That single timer contact is in series with the lid switch so a failure of either will prevent operation of both timer motor and drive motor.
Eric
