howitzer
#1 Posted : Friday, July 5, 2013 7:42:30 AM(UTC)
howitzer
My GE Profile dishwasher has water in the tub base when the dishwasher is not in use. (The water is clean and a little soapy) After running the dishwasher, the tub is dry and clean. After a day or so, the tub is filled with water again, but not consistantly and this problem had only occured in the last noght or so. Sometimes it will go a week or more before filling up again. The drain is not clogged and I have the proper air gap, could this be a faulty water inlet valve or something else?
Thanks!
#2 Posted : Friday, July 5, 2013 12:53:03 PM(UTC)
Views messages in topic : 19,638
Parts for GE PDWT180R30SS Dishwasher - AppliancePartsPros.com
Since you are confident that the drain is set up correctly then I would say that you water valve (item 744 in the Body Parts section) is leaking intermittently.
Another confirmation of this would be if the water in the tub is clean.
howitzer
#3 Posted : Friday, July 5, 2013 1:24:22 PM(UTC)
howitzer
Thanks, I was thinking that, but was not 100%. I will keep you posted.
