carl-761
#1 Posted : Monday, July 1, 2013 4:48:41 PM(UTC)
carl-761
The fridge was working good but the freezer was not freezing ice cream every thing else ok. Now everything has melted in freezer and the fridge is getting warm to. The compresser is running the fan is running what could it be thank you for your time.
#2 Posted : Wednesday, July 3, 2013 5:21:42 AM(UTC)
Parts for Frigidaire FRS6R4EWC Refrigerator - AppliancePartsPros.com
First confirm that the compressor is running all the time other than when the unit goes through a defrost cycle.
You can usually hear it but also should be able to feel it vibrating.
Is the fan you say is running the evaporator/freezer fan or the condenser/compressor fan?
Confirm that the evaporator fan is running.
If it is running all the time, remove the cover in the freezer so you can inspect the evaporator coils.
If they are heavily iced/frosted over you have a defrost problem.
If there is no frost or frost in just one area (usually where the freon enters the coils) then you have a sealed system problem and it will be an expensive repair.
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
Samsung Refrigerator Freezer Model #FJ24J9960S4/AA (Refrigerator & Freezer Repair)
by macdav2022 12/3/2022 5:36:36 PM(UTC)
Refrigerator freezer either too cold or too warm, running continually (Refrigerator & Freezer Repair)
by coolforcats 11/26/2022 3:15:56 PM(UTC)
1985 Kenmore 18 refrigerator freezer went warm recently (Refrigerator & Freezer Repair)
by Guest 5/27/2022 6:35:04 PM(UTC)
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 2/25/2022 5:39:48 AM(UTC)
Both refrigerator freezer and cabinet below freezing (Refrigerator & Freezer Repair)
by Guest 2/22/2022 2:21:25 PM(UTC)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
KFIS29BBMS03 KitchenAid Refrigerator freezer only gets to 17 degrees, Fridge seems okay at 38 (Refrigerator & Freezer Repair)
by JCohen8008 6/28/2021 8:00:28 AM(UTC)
Whirlpool Refrigerator Freezer Section Intermittently Not Cooling or Making Ice (Refrigerator & Freezer Repair)
by dreeves1822 2/4/2021 6:05:32 AM(UTC)
GX2FHDXVB00 whirlpool refrigerator freezer not freezing (Refrigerator & Freezer Repair)
by Nwhe54 12/21/2020 8:30:23 AM(UTC)
Sumsung refrigerator freezer problem (Refrigerator & Freezer Repair)
by DRJHNJHNSN 4/12/2020 7:59:12 AM(UTC)
Viking 48" refrigerator freezer getting too cold (Refrigerator & Freezer Repair)
by nmunn 5/14/2019 3:11:57 PM(UTC)
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
GE Refrigerator freezer and food not cold enough (Refrigerator & Freezer Repair)
by Jerrysing 9/30/2016 6:31:22 AM(UTC)
Frigidair refrigerator freezer cold refrigerator warm. (Refrigerator & Freezer Repair)
by Dennypccc1 9/7/2016 6:50:59 PM(UTC)
