mikethevike84
#1 Posted : Friday, April 24, 2009 5:25:25 PM(UTC)
mikethevike84
I have no volt/ohm meter...How can I trigger my defrost cycle so I can see if my new defrost heater is working? It's been 24 hours, an even has frost formed on the coils, but no sign that the new heater has done anything.
I've since read that replacing these
Thermostat def
Part Number: AP3884317 made by GE
241 Sensor temp ff
Part Number: AP3185407 made by GE
is recommended at the same time you replace, should I go ahead and do that too? I hate to put it back together only to find it hasn't been fixed.
applianceman
#2 Posted : Friday, April 24, 2009 6:01:10 PM(UTC)
applianceman
On this model I would say that it is the heater 99% of the time and it can be up to 48 hours between defrost cycles depending on the amount of door openings. Work on these all the time and haven’t seen many sensors bad. Don’t get me wrong I am not by any means saying that something else can't cause your problem just that its more than likely fixed. Refrigerator repair guide
applianceman
#3 Posted : Friday, April 24, 2009 6:03:47 PM(UTC)
applianceman
[FONT='Times New Roman']Also you need to put the evaporator back on for proper airflow. [/FONT]
mikethevike84
#4 Posted : Friday, April 24, 2009 6:47:57 PM(UTC)
mikethevike84
Ok, thanks applianceman, that sounds encouraging.
