Hello. My barely used almost 3 y.o. dishwasher broke. I only used it for light or normal cleaning maybe every 1-2 even 3 months. But this tuesday i also pressed sanitize button (which was first time ever, we never used this option before). So in the morning when i woke up, dishwasher buttons were off, I opened it everything was clean, but dishwasher had a lot of water on the bottom! It was almost spilling over opened door! Not one button works, so I do not know what happenes at night... at what point dishwasher stopped working..... Is it control panel? Is it touch pad? Then why water didn't get drained?..
Please recommend part needed for my dishwasher. Thank you so much!
Groups: APP Team
Hi. Check if there is power at the wall outlet. Next , check if the thermal fuse is not blown. You can find it inside the control panel Part number: W10258275
thank you. I will reply if it helped or not after I get my hands to it on this weekends and try to do what you recommended.
Groups: APP Team
Hello, finally I got help with checking power and thermal fuse. There is power and fuse is ok. Everything inside that panel looks good and not damaged. Could you please suggest next move? Thank you.
