jtanthony
#1 Posted : Friday, June 28, 2013 3:54:29 PM(UTC)
jtanthony
the control pad will only let you set the temp in the fridge to 34 but it is staying at 37 after being closed all night. could this be a damper issue or is this fridge different?
#2 Posted : Sunday, June 30, 2013 1:45:28 AM(UTC)
Check the freezer temperature, should be below zero.
andec
#3 Posted : Sunday, June 30, 2013 8:10:48 AM(UTC)
andec
thank you richappy,
If I disconnect the defrost heater and manually defrost is it possible for the rest of the refrigerator to still function? Andec
#4 Posted : Sunday, June 30, 2013 8:23:14 AM(UTC)
Yes, if the freezer evaporator is free of ice, the freezer temperature should have no trouble getting below zero and the airflow into the fridg will improve, driving the temperature lower.
