twjackson
#1 Posted : Wednesday, June 26, 2013 9:42:29 AM(UTC)
twjackson
the fan in the freezer is working but not freezing nor making ice & the frig is not cooling at all..plz someone help
#2 Posted : Wednesday, June 26, 2013 10:43:50 AM(UTC)
Is the compressor running.
You can usually hear it but you should also be able to feel it vibrating.
If it is and there is no frost on the evaporator coils in the freezer then you have a sealed system problem.
Frige not cold enough freezer fine+fix? (Refrigerator & Freezer Repair)
by tomsap 5/8/2022 2:02:41 PM(UTC)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
RS25AGXNQ00 not cold either side (side by side) (Refrigerator & Freezer Repair)
by thisdoesfine 11/18/2021 4:53:02 AM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
fridge freezing up anf not cold (Refrigerator & Freezer Repair)
by mobetter 7/6/2021 8:51:05 PM(UTC)
LG not cold (Refrigerator & Freezer Repair)
by Guest 6/23/2021 5:19:40 AM(UTC)
Whirlpool side by side GD5SHAXN cooling but not cold (Refrigerator & Freezer Repair)
by Guest 4/20/2021 7:58:33 AM(UTC)
LG Refrigerator model LMX28987ST intermittently not cold (Refrigerator & Freezer Repair)
by moocowman 2/1/2021 6:06:52 PM(UTC)
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 1/28/2021 9:00:51 AM(UTC)
Wine cooler not cold, compressor working (Refrigerator & Freezer Repair)
by CafeRoaster 6/17/2020 4:38:13 PM(UTC)
Imperial Heavy Duty - UL1793CA2 Freezer stays around 60 degrees but not colder (Refrigerator & Freezer Repair)
by mileyg 6/11/2020 8:02:58 AM(UTC)
refridgerator section is not cold enough (Refrigerator & Freezer Repair)
by androidx1 6/8/2020 9:38:34 AM(UTC)
LG refrigerator lxfs28566s not cold enough. (Refrigerator & Freezer Repair)
by amagie00 5/16/2020 9:08:51 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
