My son left his chain in his pocket and washed his pants. I saw the chain in one of the draining holes & attempted to get it out but couldn't. It has since drained away. however since then, the washer has not been draining properly. If you put it through a second spin cycle it does.
How do I fix said problem without involving a service repair and paying an extravagant amount of $ for them to drive out to tell me what the problem is.
Dwinx
Groups: Expert
does this mean I have to change the pump
Groups: Expert
Not necessarily, you need to disconnect the drain hoses and look for an obstruction. The chain may be stuck in the pump or may have damaged the impeller.
Eric
what does it mean if the impeler is damaged
Thanks a bunch. Tppk it apart last night. Found an underwire, no chain. Did 2 washes after. Looks good.
