AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool Duet Sport door locked add garment light flashing
My Whirlpool Duet Sport (WFW8300SW04) tripped the breaker and stopped in the middle of a cycle. Didn't drain and door wouldn't unlock. Used manual latch to open door and reset breaker, drained washer. Now it will power on, but when I try and start a cycle the door locks and add garment light flashes, but that's all I've got. Getting F-28 error code. Should I jump straight to replacing the motor control unit or is there a checklist I should run through first?
Originally Posted by: mhc0005 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My Whirlpool Duet Sport (WFW8300SW04) tripped the breaker and stopped in the middle of a cycle. Didn't drain and door wouldn't unlock. Used manual latch to open door and reset breaker, drained washer. Now it will power on, but when I try and start a cycle the door locks and add garment light flashes, but that's all I've got. Getting F-28 error code. Should I jump straight to replacing the motor control unit or is there a checklist I should run through first? Same problem here as well, any insight highly appriciated
Originally Posted by: singe ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Same problem here as well, any insight highly appriciated Did this get resolved? I have a similar issue...
Washer Repair
