STP5353
#1 Posted : Monday, June 24, 2013 7:26:05 AM(UTC)
STP5353
Replacing The Clutch Assy. Have Disengaged The Agitator, Removed Motor, And Bolts For Transmission, However, Shaft Will Only Come Out About 2-3 Inches And Then Binds- I Don't Want To Force It. Help
fairbank56
#2 Posted : Monday, June 24, 2013 10:04:33 AM(UTC)
fairbank56
Groups: Expert
If this is a model with the fabric softener dispenser on top of the agitator, make sure to remove the metal clip from the top of the agitator shaft. If that's not the problem, then you will need to get someone to use a wood block and hammer to tap on the agitator shaft while you pull from the bottom. Make sure the exposed part of the agitator shaft is thoroughly clean of gunk and rust/corrosion.
Eric
washer agitator shaft. (Washer Repair)
by roots398 1/19/2021 8:27:49 AM(UTC)
Maytag LAT9416AAE washer - agitator shaft pops out (Washer Repair)
by larrylarry24 8/10/2020 5:05:00 PM(UTC)
Agitator shaft pulls out (Washer Repair)
by Nae 7/15/2016 7:25:13 PM(UTC)
water leaking between agitator shaft (Washer Repair)
by fhorta 3/2/2014 7:27:17 PM(UTC)
GE washer agitator shaft replacement (Washer Repair)
by Dapper Merchandise 8/15/2011 11:44:46 AM(UTC)
Cant get Agitator Shaft to get back in correctly (Washer Repair)
by AlmostAHandyman 4/18/2010 4:58:52 PM(UTC)
