robert.ar
#1 Posted : Wednesday, September 26, 2012 8:06:52 PM(UTC)
robert.ar
My wife just broke the left most knob on this portable kenmore washer - it is the load Water Level knob, and i can still change it with a pair of needle noze pliers, but would like to have it repaired correctly if not too much difficulty
1. I bought this used over twelve years ago. I do not see a model number, and some of the paper diagram on the back is peeling away/unreadable. Where might the model number indicated?
2. The control panel is at the front, has three knobs: Water Level, Water Temp, and the larger Wash Selector Knob at the right. At a glance it appears the top panel (including lid and control panel) is attached with four screws at the top/back of the machine. Is this the only way to access the control panel, or does it somehow pop out with a screw driver and a little force?
The plastic knob post appears to have simply broken in half. From reading other posts, i suspect that the whole control, or maybe even the whole board might need replacement. Is this correct?
Any other advice on the problem? Is a pair of needle nose the best option?
Thanks for any help
#2 Posted : Thursday, September 27, 2012 2:14:05 PM(UTC)
Robert,
It is impossible to find any replacement part without the correct model number. Check under the lid and on all sides of the cabinet.
robert.ar
#3 Posted : Friday, September 28, 2012 9:32:06 PM(UTC)
robert.ar
Robert,
Thanks gene. I never noticed the tag under the lid...
Mine is model 110.94572201
#4 Posted : Saturday, September 29, 2012 4:11:08 PM(UTC)
Robert,
I'm assuming that at least a part of the water level switch stem is broken off. The water level switch has to be replaced. Unfortunately the knob for this switch is no longer available.
- The water level switch Part number: 3966789
robert.ar
#5 Posted : Saturday, September 29, 2012 4:56:41 PM(UTC)
robert.ar
Robert,
Is this the part that is found at the control panel? Attached to the knob?
#6 Posted : Saturday, September 29, 2012 7:06:29 PM(UTC)
This is the very left switch which is mounted from the inside of the control panel.
ewdUjDroHX
#7 Posted : Friday, June 21, 2013 5:53:29 AM(UTC)
ewdUjDroHX
<a href=http://mudchute.org/stats/vicodin/#49575>buy vicodin</a> vicodin recreational use - vicodin dosage watson 349
