2 Pages12>
beachrog
#1 Posted : Wednesday, April 22, 2009 4:07:50 AM(UTC)
beachrog
This morning I noticed the burner indicator light up by the knobs would not go off. This is different than the hot surfact indicator on the glass top itself. Although that light was illuminated as well but I'm not sure if that's because I was turning them on and off trying to get the other light to go off. They click when you get to off, however that indicator light is still on. Because I needed to get to work, I simply cut the power at the breaker to ensure I didn't come home to a burner that was on all day.
I replaced the control panel last fall and it's been working great. I know nothing of the mechanics of the knobs and wasn't sure how to go about testing to see if it's the knob, wire, or what.
Any insight is appreciated.
#2 Posted : Wednesday, April 22, 2009 4:17:45 PM(UTC)
Most likely the problem is a bad switch for this burner.
Here are the breakdown diagrams and Replacement parts for MAYTAG MER6772BAQ | AppliancePartsPros.com
beachrog
#3 Posted : Friday, April 24, 2009 5:24:16 AM(UTC)
beachrog
Thanks Gene,
I'm not sure which switch according to the diagram I would try replacing. There seems to be one switch labeled as #4, but the list of parts provides 3 different #4s. They are cheap enough I assume it's just easier to replace both of them on that side. Do you know which of these three would be the right one:
Switch Element (dual)
Switch-in
Switch Infinite
Perhaps it varies by model and I'll have to pull one first?
#4 Posted : Saturday, April 25, 2009 6:06:58 PM(UTC)
Which element is this switch for: small, large or dual?
beachrog
#5 Posted : Monday, April 27, 2009 4:04:17 AM(UTC)
beachrog
There are two burners on that side, one small and one large. Again, I'm assuming I'd have to replace them both since I don't really have a way to check and see if just one is bad.
I'm also assuming based on that I'd need one Switch-in and one Infinite, but that's by process of elimination. How do you know by the labeling which one is for which type of burner. Dual is self explanatory but the others have me puzzled.
#6 Posted : Monday, April 27, 2009 1:30:35 PM(UTC)
It should be marked on the control panel, on the knobs or around the knobs something like "RF" or "Right Front". Also you should notice which burner gets hot when you turn the knob "on".
beachrog
#7 Posted : Tuesday, April 28, 2009 4:34:56 AM(UTC)
beachrog
Thanks Gene,
I guess I was referring to identifying which is which in the parts list, not on the stove itself. Identifying which knob goes to which burner on the stove shouldn't be hard at all.
#8 Posted : Wednesday, April 29, 2009 2:08:14 PM(UTC)
The part number for the switch used for the large element is AP4101874
The part number for the switch used for the small element is AP4101865
beachrog
#9 Posted : Thursday, April 30, 2009 4:49:48 AM(UTC)
beachrog
Thanks for your patience with me Gene. When I click on those links both of them clearly state which element they are for. I'm not sure why I missed that before.
Your help is greatly appreciated.
#10 Posted : Thursday, April 30, 2009 1:28:05 PM(UTC)
Guest (7)
2 Pages12>
