I need some help wiring up my new drive motor. Model #10410892 It has a different switch on it for the wiring connections. I have a Magtag dryer model #LDE8404ACE The wires to connect are as follows: Two black wires that connect together Two yellow wires that connect together One blue wire One red wire One grey wire with a blue jumper I need to find out which terminals to connect them to on the new unit. Thank you.
I cannot find any info on the given part number.
You could look up your model at AppliancePartsPros, then click on the motor. A new page will open with info about the replacement motor includes a Q&A section.
I have no way of knowing if this part is the same as the part you have. |
THIS FORUM IS DEAD!!!!!!! |
More info on my dryer drive motor Part # AP5272724 P/N -W10410892 Model# S58SVEET-7126 Thank you for your quick response, denman
Groups: APP Team
Hi. The motor part #W10410999. You will want to wire the unit in accordance with the electric wiring rather than the gas. The Yellow will go where it was originally connected to #6, Red wire to #5, gray wire to 1/4" thermal protector tab, Black wire to #2, and blue and white to #1. You may need to put the jumper between 1 and 5. Simon.
When you say to hook gray wire to 1/4" thermal protector tab, Is that the same as the #2 position on the switch terminals. Terminal #2 is the far left position on the switch block. Thank you, Simon
I got my dryer back in operation tonight. Your wiring directions were right. I looked at the manual you suggested and it helped me understand how the switch operates and the location of the thermal protector tab. Thanks for your help.
Groups: APP Team
That is my pleasure.
Simon.
Hey it’s a great info you’ve shared Simon. Thanks for sharing it.
Groups: APP Team
