davisgu80
#1 Posted : Thursday, June 13, 2013 6:57:50 PM(UTC)
davisgu80
I need some help wiring up my new drive motor. Model #10410892
It has a different switch on it for the wiring connections.
I have a Magtag dryer model #LDE8404ACE
The wires to connect are as follows:
Two black wires that connect together
Two yellow wires that connect together
One blue wire
One red wire
One grey wire with a blue jumper
I need to find out which terminals to connect them to on the new unit.
Thank you.
#2 Posted : Friday, June 14, 2013 2:19:10 AM(UTC)
I cannot find any info on the given part number.
You could look up your model at AppliancePartsPros, then click on the motor.
A new page will open with info about the replacement motor includes a Q&A section.
I have no way of knowing if this part is the same as the part you have.
davisgu80
#3 Posted : Friday, June 14, 2013 3:24:10 AM(UTC)
davisgu80
More info on my dryer drive motor
Part # AP5272724
P/N -W10410892
Model# S58SVEET-7126
Thank you for your quick response, denman
#4 Posted : Friday, June 14, 2013 4:22:28 AM(UTC)
Part number: AP5272724
Click on the above picture and a new page will open with more info.
Looks like the motor should have come with a hook up sheet.
Here is a manual. You will have to join the site to be able to download the manual.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=53
Simon / APP Team
#5 Posted : Friday, June 14, 2013 9:39:52 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The motor part #W10410999.
You will want to wire the unit in accordance with the electric wiring rather than the gas. The Yellow will go where it was originally connected to #6, Red wire to #5, gray wire to 1/4" thermal protector tab, Black wire to #2, and blue and white to #1. You may need to put the jumper between 1 and 5.
Simon.
davisgu80
#6 Posted : Saturday, June 15, 2013 5:26:33 AM(UTC)
davisgu80
When you say to hook gray wire to 1/4" thermal protector tab,
Is that the same as the #2 position on the switch terminals.
Terminal #2 is the far left position on the switch block.
Thank you, Simon
davisgu80
#7 Posted : Saturday, June 15, 2013 7:20:32 PM(UTC)
davisgu80
I got my dryer back in operation tonight. Your wiring directions were right.
I looked at the manual you suggested and it helped me understand how the
switch operates and the location of the thermal protector tab.
Thanks for your help.
Simon / APP Team
#8 Posted : Sunday, June 16, 2013 12:45:29 AM(UTC)
Simon / APP Team
Groups: APP Team
That is my pleasure.
Simon.
jacobwilson8
#9 Posted : Wednesday, June 19, 2013 4:10:36 AM(UTC)
jacobwilson8
Hey it’s a great info you’ve shared Simon. Thanks for sharing it.
Simon / APP Team
#10 Posted : Wednesday, June 19, 2013 4:29:49 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
