motox92
#1 Posted : Sunday, June 16, 2013 11:17:25 AM(UTC)
motox92
The damper door on my 02 Frigidaire was stuck open. I took it apart and shut it and now it wont open. Do i need to replace to control box and damper or could the problem be somewhere else? Thank you for you response.
#2 Posted : Monday, June 17, 2013 2:09:02 AM(UTC)
Parts for Frigidaire FRS26HF6BB0 Refrigerator - AppliancePartsPros.com
Here is a better copy of the wiring diagram
http://manuals.frigidaire.com/p...f/Anderson/240389607.pdf
Since it will not open or close odds are that you need a new damper assembly.
You could check the fresh food thermostat with a meter to make sure that it is OK.
motox92
#3 Posted : Monday, June 17, 2013 9:20:01 AM(UTC)
motox92
Thank you i will look in to it.
