kmpadilla
#1 Posted : Sunday, June 16, 2013 8:09:59 AM(UTC)
kmpadilla
I have a fridgidaire stackable washer/dryer that is less then 6months of use according to previous owner. it was working great then all of a sudden the washer in middle of a cycle just stopped working and now it wont do anything I had to manually drain it ,and now the dryer wont heat up can you PLEASE give me some advise as to what to do to troubleshoot these problems Thank you
sidfink43
#2 Posted : Wednesday, June 19, 2013 12:10:45 PM(UTC)
sidfink43
This sounds like an electrical problem, possibly one leg of your 220 volt circuit is out. So first use a meter to check and make sure you are getting 110 volts out of each side of the socket.
If that is okay, then use the wiring diagram to try and trace the wiring and see if there is a short somewhere.
Washer stopped working in middle of cycle (Washer Repair)
by mc22 6/7/2011 7:06:35 AM(UTC)
