sevykor
#1 Posted : Wednesday, June 12, 2013 10:59:36 AM(UTC)
sevykor
I recently noticed a re-occuring issue with my Maytag Performa Gas Oven when I preheat at 370 or above. At some point, as the temperature increases, the stove makes a "fart" noise on and off. The trouble is that it has difficulty pre-heating to higher temperatures. Sometimes when it does preheat, it does the "fart" thing again when it is trying to maintain temperature. I am including a youtube link so that you can see and hear what is going on here (http://youtu.be/adERFN5LKds).
If someone knows what needs to be fixed, please help. I am not looking forward to replacing the entire oven. Thanks all!
Simon / APP Team
#2 Posted : Wednesday, June 12, 2013 11:36:55 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
What is the complete model and serial number of the unit?
You need to check the oven igniter amps draw. Use a clamp on amp meter over one of the igniter wires. If the reading is below 3.2 amps - you should replace the igniter. If it is good - the safety gas valve is most likely defective.
For the assistance with the part numbers we need the range model.
Simon.
sevykor
#3 Posted : Wednesday, June 12, 2013 11:46:13 AM(UTC)
sevykor
Model: PGR5710BDW
Simon / APP Team
#4 Posted : Wednesday, June 12, 2013 12:55:06 PM(UTC)
Simon / APP Team
Groups: APP Team
Guest (4)
