Douglas Scherer
#1 Posted : Wednesday, June 12, 2013 7:44:53 AM(UTC)
Douglas Scherer
Dishwasher fills with water but doesn't run. timer clicks as it advances but motor does not run.
Simon / APP Team
#2 Posted : Wednesday, June 12, 2013 11:08:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You should check if there is 120 Volts AC coming to the motor after the fill cycle. Use the multimeter to check between Yellow and Blue at the motor connector. If the correct voltage is present then the motor is bad. If no voltage, check the wiring harness to the timer, and if it is good - you should replace the timer.
Here are the breakdown diagrams and Pump and Motor parts for Whirlpool DU912PFGZ1 - AppliancePartsPros.com
Thank you.
Simon.
Douglas Scherer
#3 Posted : Saturday, June 15, 2013 5:28:22 PM(UTC)
Douglas Scherer
Thanks. I checked for voltage at the pump and had 120 vac. Noticed chalky white corrosion in the plug and all over the motor. Water leak caused the motor to freeze up. Cost to repair too much for the age of the machine. time to replace.:(
Simon / APP Team
#4 Posted : Sunday, June 16, 2013 12:41:48 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
