Don
Don ML
#1 Posted : Monday, June 10, 2013 9:19:27 AM(UTC)
Don ML
Both broilers stopped working even though the baking elements continue to work.
Simon / APP Team
#2 Posted : Monday, June 10, 2013 10:34:55 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
According the wiring diagram the each broil element in your oven is powered up by it own relay board. That mean there are two problems not one.
You should start with checking each broil element for continuity.
Turn off the circuit breaker and pool each broil element so you can use a multimeter. Remove one wire from the element and check the continuity between the contacts.
In case if there is no continuity, you should replace the element(s).
They both are identical.
The broil element Part number: 5303016247
Here are the breakdown diagrams and Control Panel parts for Frigidaire GLEB27T8CBA - AppliancePartsPros.com
Please, post the results.
Simon.
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Washer belts dont fit (Washer Repair)
by daviwyat 8/8/2022 12:24:54 PM(UTC)
Whirlpool motor? Repair it, don’t replace! (Washer Repair)
by Guest 6/22/2022 5:02:05 PM(UTC)
clothes washer don't work, troubleshooting manual wtw5500xw0 cabrio (Washer Repair)
by paulmars 4/2/2022 10:43:24 AM(UTC)
Don't trust the JAZZ board diagnostics!! (Refrigerator & Freezer Repair)
by Stahlmaster 9/8/2021 3:22:06 PM(UTC)
What damage have I done? (Dishwasher Repair)
by 713cableman 8/26/2021 7:14:26 AM(UTC)
Replaced LED light panel, lights still don’t work (Refrigerator & Freezer Repair)
by Shyuhjrf 8/25/2021 8:01:44 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Frigidaire gallery wall oven will not maintain temperature. It is just a year old and had done this (Oven Repair (including Ranges and Cooktops))
by Guest 6/5/2021 7:52:53 AM(UTC)
Viking range ovens, broiler, and griddle don’t turn on (Oven Repair (including Ranges and Cooktops))
by Guest 5/19/2021 11:02:20 AM(UTC)
Bosch dual fuel range burners all spark but 2 burners don't ignite (Oven Repair (including Ranges and Cooktops))
by elizabeths 2/24/2021 8:16:50 AM(UTC)
Maytag ice maker not making ice, I don’t know what else to try... (Refrigerator & Freezer Repair)
by Karnsky 12/11/2020 5:09:39 PM(UTC)
Kenmore C970-656024 - display and outlets don't work, stove does (Oven Repair (including Ranges and Cooktops))
by Zealot 12/4/2020 9:14:03 AM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
Some burners don’t spark (Oven Repair (including Ranges and Cooktops))
by search4f 5/4/2020 12:33:46 AM(UTC)
