2 Pages12>
SaintsFan67
#1 Posted : Friday, May 31, 2013 1:53:05 PM(UTC)
SaintsFan67
Hi - I have an older Whirlpool Super Capacity Washing Machine with direct drive. Several weeks ago it stopped spinning and I replaced the couplings. It worked fine for several weeks - every once in a while it had a slight burning smell - but for the most part ran ok. Today while in the spin cycle it tripped a breaker. When I reset the breaker - it would not resume and just hummed and thats all it does. What does this sound like to you guys? Bad Motor?
Randy
fairbank56
#2 Posted : Friday, May 31, 2013 2:31:08 PM(UTC)
fairbank56
Groups: Expert
Remove cabinet, jump out lid switch, remove pump from motor and see if motor will run. If not, remove motor and try it while sitting on floor. Place your foot on motor before starting as it will jump if it starts. What is model number of washer? Is it agitating ok?
Eric
SaintsFan67
#3 Posted : Friday, May 31, 2013 2:54:49 PM(UTC)
SaintsFan67
Where do they hide the Model # ? - All I can find is Whirlppol Super Capacity Plus
SaintsFan67
#4 Posted : Friday, May 31, 2013 2:58:14 PM(UTC)
SaintsFan67
Oh and its not agitating - just full of water and humming
fairbank56
#5 Posted : Friday, May 31, 2013 4:26:14 PM(UTC)
fairbank56
Groups: Expert
Model number is usually under the lid
SaintsFan67
#6 Posted : Friday, May 31, 2013 4:34:08 PM(UTC)
SaintsFan67
its not under the lid :confused:
fairbank56
#7 Posted : Friday, May 31, 2013 4:42:29 PM(UTC)
fairbank56
Groups: Expert
snadeau
#8 Posted : Tuesday, November 12, 2013 3:23:19 PM(UTC)
snadeau
Mine is doing this same thing. I replaced the lid switch and the motor drive switch. The machine will fill but won't spin. If I manually push the white button on the motor switch it will spin. What could be wrong? Please help :)
Appliance Ninja
#9 Posted : Tuesday, November 12, 2013 3:33:21 PM(UTC)
Appliance Ninja
You likely have a connector on the motor that has become loose and is not making good connection with the Molex connector. Usually the brass colored tab on the motor will look burnt or the white plastic will be discolored. See any such marks around the motor plug connector?
snadeau
#10 Posted : Tuesday, November 12, 2013 3:42:00 PM(UTC)
snadeau
No I don't see anything like that :(
Guest (8)
2 Pages12>
