RichardU
#1 Posted : Sunday, May 26, 2013 10:46:54 AM(UTC)
RichardU
My 36" Viking All Refrigerator is dripping onto the floor instead of the pan. I would imagine the drain line is clogged.
Can anyone please tell me where to find the drain line or how to clean it?
RichardU
#2 Posted : Tuesday, May 28, 2013 4:42:16 AM(UTC)
RichardU
Are service manuals available for Viking?
VikTech
#3 Posted : Tuesday, May 28, 2013 6:03:04 PM(UTC)
VikTech
Yes but only for authorized servicers. Your evaporator is located on the back wall at the top. There is a drain trough under the evap and the drain tube is on the left. It's not common for the drain to be clogged due to its location.
A little lower than half way down on the rear wall look for icing. There is a secondary evap that could be iced over due to a refrigerant leak or failed fan.
RichardU
#4 Posted : Wednesday, May 29, 2013 1:47:05 PM(UTC)
RichardU
Thanks for your reply. Is this accessible from inside or will I need to pull the unit out of the cabinet?
RichardU
#5 Posted : Monday, June 3, 2013 9:58:38 AM(UTC)
RichardU
Does anyone else have any insight on how to access the drain line on a Viking refrigerator?
