Trying to fix my daughters washer. It will not drain or spin. It fills, aggitates and then does nothing. You can hear it clicking through the entire cycle but nothing more happens. You turn it to just before 'spin' and let it advance to 'spin' on its own and nothing happens. No clunks, nothing like the motor is trying to spin, nothing. It is not the lid switch. I thought it was and bought a new one and it did not help. Again, the dial moves through all the cycles, but it will not drain or spin. I manually drained it, so it is not clogged. Any ideas.
Groups: Expert
Sounds like a faulty timer. Can you post a clear photo of the wiring diagram? Should be pasted to left side of inside of back panel behind control panel and cabinet. Open control panel and remove cabinet to gain access.
Eric
Groups: Expert
Got a copy of your wiring diagram. If you hear no noise at all from the drive motor as timer advances through drain/spin, then it appears you have a faulty timer. Eric
