wrayman
#1 Posted : Monday, May 20, 2013 5:55:48 PM(UTC)
wrayman
Hello,
New here, so please forgive any mistakes.
I have an GX5FHDXTQ00 bottom freezer Whirlpool.
Recently I experienced the COLD Freezer / Warm Refrigerator syndrome and had I listened to "internet" how too's I perhaps would have replaced a working part.
Visual inspection yielded a verification of unusual amount of ice in the rear of the freezer compartment.
First I checked the evaporator heater (defrost heater) and it showed 28 Ohms, or "shows good".
The defrost thermostat seems to work fine as long as it is at 20 F (dipping in ice water did not trip the bi-metal) I first used a can of air (inverted) and that tripped the bi metal, and then I placed it in a working freezer and it also tripped (closed contacts) and it opened when taken out. I wished I hadn't cut the defrost thermostat out to check it, but I guess I wouldn't have known for sure. I suppose the bi-metal thermostat could be out of tolerance, I know it supposed to close at 20F
I checked the evaporator motor and it is also good. I am not sure how to test the damper door, but even when the unit was running warm, I could feel some air flow through the output vent in the refrigerator compartment.
All this long and drawn out post is to ask what might be wrong with my unit. It was certainly iced up. The drain also appears to working.
I have my refrigerator in pieces and I am scratching my head. At this point
I am hopeful that someone that knows about this model may have had similar issues so that I may resolve mine as well.
#2 Posted : Tuesday, May 21, 2013 3:11:20 AM(UTC)
Probably a bad control board in this AP5657149 You will need to peal off the control panel overlay to get at the mounting screws.
If you open and close the fridg light switch 5x in six seconds, the fridg should go in defrost if every thing is in place in the freezer. If not, replace the control.
wrayman
#3 Posted : Tuesday, May 21, 2013 10:52:29 AM(UTC)
wrayman
Forced Defrost Mode and defrost heater operates (checked by measurement and visually).
What is next?
#4 Posted : Tuesday, May 21, 2013 12:30:37 PM(UTC)
I would change the defrost limiter in the freezer, they can become intermittent.
wrayman
#5 Posted : Tuesday, May 21, 2013 3:03:35 PM(UTC)
wrayman
Defrost Limiter? (Is this also called the defrost thermostat?)
#6 Posted : Wednesday, May 22, 2013 12:16:06 AM(UTC)
Yes it is, a round object.
Kitchenaid Undercounter fridge defrost problem KUDF204ESB00 (Refrigerator & Freezer Repair)
by glenn.anderson82@yahoo.com 6/14/2021 6:41:38 AM(UTC)
Trying to Troubleshoot Defrost Problem (Refrigerator & Freezer Repair)
by webenji 3/29/2020 9:21:34 PM(UTC)
Whirlpool Gold gs5shaxnl02 Defrost Problem / Freezer Side too warm (Refrigerator & Freezer Repair)
by Steve_B 4/21/2019 3:03:18 PM(UTC)
Fridge defrost problem (Refrigerator & Freezer Repair)
by Leeowens 12/15/2017 9:14:42 AM(UTC)
Kenmore Eliite refer defrost problem (Refrigerator & Freezer Repair)
by rascalrick 11/28/2016 2:08:19 PM(UTC)
Whirlpool Gold Refrigerator Defrost Problem (Refrigerator & Freezer Repair)
by TheDoctorsCompanion 8/23/2016 12:47:07 PM(UTC)
by Mad_Cow 3/14/2016 7:20:21 PM(UTC)
Defrost Problem Kenmore Fridge (Refrigerator & Freezer Repair)
by smackover 7/14/2015 4:13:25 PM(UTC)
ADC Defrost Problem (Refrigerator & Freezer Repair)
by edscustom 3/21/2015 6:37:37 AM(UTC)
whirlpool side by side defrost problem (Refrigerator & Freezer Repair)
by dermitt3 11/23/2014 4:37:30 PM(UTC)
by dsnider77 9/24/2014 7:33:30 PM(UTC)
by jpsims 9/10/2014 2:30:57 PM(UTC)
Fridge Warm and Defrost Problem (Refrigerator & Freezer Repair)
by gmon1001 9/10/2014 10:53:11 AM(UTC)
by goldbergg70 9/8/2014 10:41:41 AM(UTC)
by guysquestion 9/3/2014 5:32:30 PM(UTC)
