marz1129
#1 Posted : Friday, May 17, 2013 12:56:39 PM(UTC)
marz1129
Had a freezer problem last month and had the motherboard, thermistor and temp sensor replaced in the freezer. The next week the damper broke and had to be replaced. Since then the fresh food side says it is 61 degrees but it freezes the milk. I had the thermistor in the fresh food side changed but no help. Any ideas?
#2 Posted : Friday, May 17, 2013 1:55:57 PM(UTC)
Hello,
Unplug the refrigerator. Remove the J1 connector from the main control board. Measure the resistance between the wires connected to the pins: J1-5 & J1-2 and J1-5 & J1-1. Measure the exact temperature in the fresh food compartment at the same time. Post the results.
Here are the breakdown diagrams and Parts for GE PSF26PGTABB Refrigerator - AppliancePartsPros.com
marz1129
#3 Posted : Friday, May 17, 2013 2:43:17 PM(UTC)
marz1129
Hello,
There are no wires connected to J1-5 at all.
#4 Posted : Monday, May 20, 2013 1:07:32 PM(UTC)
What happen to this wire?:confused:
This is the common wire for both thermistors in the fresh food compartment.
gene.
marz1129
#5 Posted : Monday, May 20, 2013 1:13:40 PM(UTC)
marz1129
gene.
Don't know about that, there was never a wire on it. I did find out that there was a third thermistor on the side of the fresh food area and it was the one that was bad. All fixed now.
#6 Posted : Monday, May 20, 2013 1:20:46 PM(UTC)
I'm glad you were able to fix it but it is very strange. Per the wiring diagram for this model number it has to be there. Have you ever replaced the main control board?
marz1129
#7 Posted : Monday, May 20, 2013 1:23:39 PM(UTC)
marz1129
The motherboard was replaced a couple of months ago to fix a problem with the freezer. There was no wire on that post then either.
#8 Posted : Monday, May 20, 2013 1:39:11 PM(UTC)
Attached it the mini-manual for this refrigerator with the wiring diagram.
File Attachment(s):
31-51677 - PSS26PSTASS.pdf (921kb) downloaded 10 time(s).
GSH22JSTESS - Refrigerator Freezing Fresh Food After Replacing Main Board with WR55X10942 (Refrigerator & Freezer Repair)
by humanpowered 1/4/2020 7:19:36 AM(UTC)
GE Refrigerator is freezing fresh food side (Refrigerator & Freezer Repair)
by MikeHam 2/1/2016 7:40:49 PM(UTC)
Whirlpool SxS fridge freezing fresh food (Refrigerator & Freezer Repair)
by PeteClements 3/22/2015 6:15:47 AM(UTC)
Older GE Refrigerator freezing fresh food (Refrigerator & Freezer Repair)
by pschroed 11/2/2012 4:53:37 PM(UTC)
frigidaire....freezing fresh food (Refrigerator & Freezer Repair)
by sabaker 4/25/2012 6:07:01 PM(UTC)
by zamguy 10/30/2011 2:49:03 PM(UTC)
refrigerator freezing fresh foods (Refrigerator & Freezer Repair)
by tdyltc46 8/31/2010 7:48:22 PM(UTC)
Never stops running and freezing fresh food (eg milk, juce, eggs.... (Refrigerator & Freezer Repair)
by ramszhang 8/31/2009 10:00:38 AM(UTC)
