str-il
#1 Posted : Thursday, May 16, 2013 4:02:50 PM(UTC)
str-il
GE Triton XL, GSD6760G00SS is stuck on the rinse cycle. The drain pump runs constantly. I filled the tub with water using a bucket, twice and when closing the door, it drains, but does not switch to the wash cycle. I also exercised the float switch, but not sure if that only functions for overflows. I tried holding the start/resent button constantly, but it won't shut off. When I open and close the door the drain pump just constantly runs.
Simon / APP Team
#2 Posted : Thursday, May 16, 2013 7:35:22 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Based on the information you provided it's a bad control board
Part number: AP3203951
Here are the breakdown diagrams and Escutcheon & Door Assembly parts for GE GSD6760G00SS - AppliancePartsPros.com
Post the results.
Simon.
str-il
#3 Posted : Friday, May 17, 2013 6:47:49 AM(UTC)
str-il
I decided to try turning the breaker on and off. I first turned the breaker off, while the unit was off, then back on. Then I started the unit and turned the breaker off and back on after about a minute. That seems to have reset the control in some way. I then was able to run several rinse cycles and have successfully ran a full wash cycle.
I will keep an eye on it and if it happens again, I will investigate a new controller board. Thank you Simon for your input.
I will post updates if it happens again. :)
str-il
#4 Posted : Thursday, June 12, 2014 6:23:40 PM(UTC)
str-il
Still working after about a year and a month later! We run it 7-9 times per week.
