tlc29450
#1 Posted : Thursday, May 16, 2013 7:53:36 AM(UTC)
tlc29450
Ice maker stopped making ice. I replaced ice maker assembly. I got about 5-6 cycles of ice made, and then it stopped harvesting ice again (there were ice cubes in tray). About 5 days later, the cycle started again, and the ice tray got about half full, then no more harvest cycle (again, ice in the tray). When I check ice tray sensor with flapper closed, the red beam continues 2 quick blinks and hesitation, etc. With the flapper closed, isn't red beam supposed to not blink and remain a steady beam? Or do you think a water fill valve problem?
Joe / APP Team
#2 Posted : Thursday, May 16, 2013 8:48:33 AM(UTC)
Joe / APP Team
Tic29450, You're most likely issue is the PC Board Kit
Part number: AP3137510
" 1. OPEN THE FREEZER DOOR > 2 PULSES FOLLOWED BY A 1 SECOND DELAY. (REPEATED) > A.THE FLAPPER DOOR ON THE EMITTER IS BLOCKING
THE BEAM.> B.THE OPTICS ARE FAULTY. 2.PRESS IN THE EMITTER FLAPPER DOOR TO UNBLOCK THE BEAM. > 2 PULSES FOLLOWED BY A SECOND DELAY. (REPEATED) > A. THE OPTICS ARE FAULTY B. LED IS ON SOLID > OPTICS ARE WORKING CORRECTLY"
Wouldn't expect the fill valve to be the issue at this point, based on your post information.
Joe / APP Team
#3 Posted : Thursday, May 16, 2013 9:23:03 AM(UTC)
Joe / APP Team
Tic29450, Based on the post information, your most likely issue is the PC Board KIt
"A. OPEN THE FREEZER DOOR 1.A.1. 2 PULSES FOLLOWED BY A 1 SECOND DELAY. (REPEATED)>THE FLAPPER DOOR ON THE EMITTER IS BLOCKING THE BEAM> THE OPTICS ARE FAULTY. B. PRESS IN THE EMITTER FLAPPER DOOR TO UNBLOCK THE BEAM.> 1.B. 1. PULSES FOLLOWED BY A 1 SECOND DELAY. (REPEATED)>THE OPTICS ARE FAULTY. 1.B.2. LED IS ON SOLID>OPTICS ARE WORKING CORRECTLY."
Wouldn't expect the water fill valve to be the issue at this point.
tlc29450
#4 Posted : Thursday, May 16, 2013 2:56:26 PM(UTC)
tlc29450
Thanks for the quick reply, Joe M. I ordered the optic sensor and we'll give a try.
Joe / APP Team
#5 Posted : Friday, May 17, 2013 5:18:04 AM(UTC)
Joe / APP Team
Great !
Just remember to remove power to the refrigerator before you start, you don't want to damage any new parts or shock yourself, working on the refrigerator. Give the refrigerator a few hours(4 to 8) to make several batches of cubes.
Let us know how the repair went, once you're finished.
tlc29450
#6 Posted : Monday, May 20, 2013 1:02:48 PM(UTC)
tlc29450
Originally Posted by: Joe / APP Team Go to Quoted Post
Great !
Joe: Optic sensor worked and I'm getting full buckets of ice. Thanks again and a fantastic website! You guys ROCK!
Joe / APP Team
#7 Posted : Monday, May 20, 2013 1:45:32 PM(UTC)
Joe / APP Team
Great !!!!!
You're Very Welcome !!!!
Just glad we could help
