Originally Posted by: Jcarlton Well I haven't had a chance to run the test yet but I did catch the arms moving full cycle. Just no water. The arms stop at the 10 o'clock position when the water should be coming in. I did thaw the black fill tube but still no water. I think when I can get the refrigerator out of the built in hole I will disconnect the water line and try and blow air through it. If the line is clear I think I will replace the fill valve. Since the ice maker is new and the emitters are new that the fill valve may be the culprit. J, You're on target. Check the fill tube from end to end, if all's OK replace the water inlet valve Part number: AP5263471
Then re run the test.
Once again thanks. You have been extremely helpful!
Originally Posted by: Jcarlton Once again thanks. You have been extremely helpful! You're Welcome !!
