gleadley
#1 Posted : Monday, May 13, 2013 6:44:02 PM(UTC)
gleadley
Just replaced auger motor and the front door display main board, the water works as before but still no ice will dispense. What's my next step?
#2 Posted : Tuesday, May 14, 2013 3:25:51 PM(UTC)
Does the ice dispenser light go dim when you push the lever?
gleadley
#3 Posted : Tuesday, May 14, 2013 3:55:46 PM(UTC)
gleadley
No, light stays the same , the door solenoid works
#4 Posted : Tuesday, May 14, 2013 4:13:09 PM(UTC)
Check the wires coming out of the freezer door at the bottom hinge.
Remove the ice bin. Tape in the door switch. Disconnect the wires from the auger motor and check for 120 VAC between them while the dispenser is calling for ice.
gleadley
#5 Posted : Tuesday, May 14, 2013 8:21:00 PM(UTC)
gleadley
No power ?
#6 Posted : Wednesday, May 15, 2013 4:15:55 PM(UTC)
What did you mean?
gleadley
#7 Posted : Wednesday, May 15, 2013 4:42:57 PM(UTC)
gleadley
i checked the power to the auger as you suggested there is no reading there
gleadley
#8 Posted : Wednesday, May 15, 2013 4:48:52 PM(UTC)
gleadley
i checked to see if the auger is getting 120 v and its not
#9 Posted : Wednesday, May 15, 2013 5:02:26 PM(UTC)
If there is nothing wrong with the wiring under the door then very likely the problem is a bad main control board. If you need the correct part number, verify and repost the model number of the refrigerator please. The model number you posted does not come up.
gleadley
#10 Posted : Wednesday, May 15, 2013 6:22:02 PM(UTC)
gleadley
Ok thx Gene
