3 Pages<123>
fairbank56
#11 Posted : Wednesday, May 8, 2013 4:58:16 PM(UTC)
fairbank56
Groups: Expert
Ok, just put together this web page. The bearing number you need is a 6205-2RS-1 It must be the "-1" type which is a "special" size, not the 6205-2RS which won't fit. The "-1" type has a 25.4mm inner bore diameter (exactly 1 inch) while the other one has a 25mm bore (too small). Don't get any oil or grease on the hubs or spring or else the spring won't grip and it won't spin. You do need to put a little grease in the ramps where the 6 activation balls go. Good luck.
Eric
ftaco96
#12 Posted : Sunday, May 12, 2013 2:19:15 PM(UTC)
ftaco96
Ok, I've got the part and am trying it now. I'm having a little trouble getting the parts off though. I don't want to scratch anything but I can't use liquid wrench on the parts either.
ftaco96
#13 Posted : Sunday, May 12, 2013 2:28:27 PM(UTC)
ftaco96
Are there any special tools or techniques you would use to get the pieces off?
ftaco96
#14 Posted : Monday, May 13, 2013 1:01:59 AM(UTC)
ftaco96
Ok, so I got everything off but the old bearing. Any tips on getting that out?
fairbank56
#15 Posted : Monday, May 13, 2013 4:29:04 AM(UTC)
fairbank56
Groups: Expert
Because of the four crimps that hold it in place, you need a large drift pin or similar and heavy hammer to knock it out.
Eric
ftaco96
#16 Posted : Monday, May 13, 2013 9:50:23 AM(UTC)
ftaco96
Ok, I have a 5 lb sledge and I can pick up a drift pin or pin set at harbor freight or lowes. I have metal files already. Is there a tool you'd suggest for doing the crimps?
ftaco96
#17 Posted : Tuesday, May 14, 2013 5:10:38 AM(UTC)
ftaco96
I have the old bearing out! That's gotta be my problem. It's all rusted and rough. So if I can get the old bearing out with the drift pin, can I not do the same with the new bearing to get it in without a great deal of filing? And is the crimping part absolutely necessary? If so, what tool would you use to do that?
fairbank56
#18 Posted : Tuesday, May 14, 2013 5:46:38 AM(UTC)
fairbank56
Groups: Expert
I used a dremel tool and just ground the crimps down a little bit to make it a little easier to get the new bearing in. I don't like the idea of banging on the new bearing too much. I assume the crimps are necessary to keep the outer bearing race from turning. I don't know how tight the bearing fit is if the crimps were ground completely away.
Eric
ftaco96
#19 Posted : Thursday, May 16, 2013 3:17:36 AM(UTC)
ftaco96
Thank you, Eric. Yesterday ended a 6 week struggle with my washer, thanks to you, and the cost was minimal. The machine runs and sounds as if I just had it delivered from the store. Your procedure and instructions worked like a charm. Thank you so much for your expertise!
fairbank56
#20 Posted : Thursday, May 16, 2013 5:19:10 AM(UTC)
fairbank56
Groups: Expert
Your welcome. Glad it all worked out and you saved a bunch of money.
Eric
Guest (7)
3 Pages<123>
