andreasenr
#1 Posted : Monday, May 6, 2013 4:53:01 AM(UTC)
andreasenr
Refrigerator starts with a clicking sound, runs for awhile then trips the GFI it is plugged into???? A service provider replaced the capacitor once before, could it be the same issue?
ApplianceJunk
#2 Posted : Monday, May 6, 2013 5:19:41 AM(UTC)
ApplianceJunk
It is not recommend that you plug refrigerators into GFI outlets to start with.
I would check the start relay on the side of the compressor. If that is ok you may have a faulty compressor.
andreasenr
#3 Posted : Monday, May 6, 2013 5:46:42 AM(UTC)
andreasenr
Appliancejunk,
Thank you for your input...I should clarify something, the frig is not plugged directly into the GFI outlet however, it is on the same circuit as a GFI, and it is popping that GFI...I'll check the starter and capacitor. Any other thoughts?
ApplianceJunk
#4 Posted : Monday, May 6, 2013 5:50:24 AM(UTC)
ApplianceJunk
If the last guy installed a 3n1 start relay/capacitor on it last time then the compressor is probably bad now.
How long ago had it been worked on?
andreasenr
#5 Posted : Monday, May 6, 2013 5:53:34 AM(UTC)
andreasenr
I'd guess it's got to be at least 3-5 years...time flies.
andreasenr
#6 Posted : Monday, May 6, 2013 7:20:19 AM(UTC)
andreasenr
ApplianceJunk
OK, I took the back off to check for any loose connections...None, I plugged it in again and monitored it to see how long it would run before popping the GFI. In less than an hour, the GFI had popped and the compressor was so HOT that I couldn't even touch it...any thoughts?
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
maytag refrigerator MRT118FFFH01 2019 (Refrigerator & Freezer Repair)
by mbay14 8/11/2022 4:34:41 AM(UTC)
Maytag Refrigerator MSS26C6MFZ00 (Refrigerator & Freezer Repair)
by kmatus 12/18/2021 3:42:53 AM(UTC)
Maytag refrigerator model mfi2568aes (Refrigerator & Freezer Repair)
by Rreyy 8/26/2021 11:20:16 AM(UTC)
maytag refrigerator/ freezer (Refrigerator & Freezer Repair)
by Guest 5/21/2021 5:09:50 AM(UTC)
Maytag refrigerator water not working for MFI2269VEQ3 (Refrigerator & Freezer Repair)
by Boman49 5/3/2020 8:52:43 PM(UTC)
Maytag refrigerator not rebooting after power failure !!! (Refrigerator & Freezer Repair)
by MoreCowbell 11/29/2019 1:56:41 PM(UTC)
Maytag refrigerator & freezer not getting cold (Refrigerator & Freezer Repair)
by jer1989 11/12/2016 12:10:43 PM(UTC)
Maytag refrigerator won't cool (Refrigerator & Freezer Repair)
by mimossi 4/25/2016 6:12:55 AM(UTC)
Maytag Refrigerator (Refrigerator & Freezer Repair)
by jer1989 4/23/2016 5:02:32 PM(UTC)
Maytag refrigerator ice/water dispenser very intermittent (Refrigerator & Freezer Repair)
by jstemper 3/21/2015 11:57:19 AM(UTC)
Maytag refrigerator (Refrigerator & Freezer Repair)
by julie clitheroe 1/22/2015 6:20:52 PM(UTC)
maytag refrigerator compressor keeps running (Refrigerator & Freezer Repair)
by Boose 10/28/2014 9:53:21 PM(UTC)
Water inlet shoot/tube freezing with ice on Maytag refrigerator (Refrigerator & Freezer Repair)
by reggieh 8/24/2014 5:56:45 PM(UTC)
Trying to find Defrost Timer on Older MayTag Refrigerator Up (Refrigerator & Freezer Repair)
by Hal H 7/14/2014 6:08:27 AM(UTC)
