Parts for Whirlpool WED5500XW0 Dryer - AppliancePartsPros.comSee the attachment for the tech sheet.
Read through it before starting.
First I would try manually turning the drum in the correct direction. It should turn fairly easily.
If OK
Since this was a dead short I then would check the power to the unit.
Try flipping the breaker off/on slowly a couple times.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the unit off and then when you try to start it.
The L1 (black) to the Neutral (white) is the half of the line for the motor.
If the above is OK
Unplug the unit.
Set your meter to the lowest resistance scale (usually 200 ohms).
Short the wires together before starting your tests to see if there is any zero offset in the meter.
The door must be closed.
At the control board check from P9-1 to P8-4. This should be a couple ohms re:the run and start windings of the motor.
then check from P9-1 to P8-5. This should be infinite ohms.
If not then the centrifugal switch 5M/6M is closed. Could be that it's contacts are welded together. Therefore the start winding is not in circuit and the motor will just sit there and hum.
If the above is OK.
Then check the motor windings, see Test 2 in the tech sheet.
You will need a multimeter also some experience working with electricity.
240 volts is very dangerous.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
