kclcpa
#1 Posted : Thursday, May 2, 2013 8:40:43 AM(UTC)
kclcpa
Cabrio dryer running but heat failed. Vent duct full of lint. Cleaned out ran dryer still no heat. So, figure thermal fuse or cut-off. No trouble can order parts.
Well...shorted ends of heating element together and turned dryer on. Tripped breaker. Reset breaker, now just hums when pushing start button.
Question...what is the most likely thing that got fried when i tripped the breaker. Where do i start checking/replacing parts? Still start with thermal fuse, cut-off, thermostat? Surely that didnt fry the motor?
Thanks so much for any input
#2 Posted : Friday, May 3, 2013 4:25:26 AM(UTC)
A model number may help other help you.
[COLOR="Blue"]
Question...what is the most likely thing that got fried when i tripped the breaker.[/COLOR]
The most likely is the control board if this unit has one but the voltage spike can take out just about any part.
[COLOR="Blue"]Where do i start checking/replacing parts?[/COLOR]
Cannot say.
Need a model number so a wiring diagram can be found and referenced.
You will probably need a multi-meter.
[COLOR="Blue"]Still start with thermal fuse, cut-off, thermostat?[/COLOR]
I am not sure what the above question is.
If a fuse or cut-out blows it disconnects the parts so if the hum is from the motor then it is not either as the motor is getting power.
[COLOR="Blue"]Surely that didnt fry the motor?[/COLOR]
Again I cannot say but a humming motor usually means a blown motor if the motor is getting 120 volts.
kclcpa
#3 Posted : Friday, May 3, 2013 9:55:00 PM(UTC)
kclcpa
WED5500XW, thanks for any help
#4 Posted : Saturday, May 4, 2013 3:29:41 AM(UTC)
Parts for Whirlpool WED5500XW0 Dryer - AppliancePartsPros.com
Read through it before starting.
First I would try manually turning the drum in the correct direction. It should turn fairly easily.
If OK
Since this was a dead short I then would check the power to the unit.
Try flipping the breaker off/on slowly a couple times.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the unit off and then when you try to start it.
The L1 (black) to the Neutral (white) is the half of the line for the motor.
If the above is OK
Unplug the unit.
Set your meter to the lowest resistance scale (usually 200 ohms).
Short the wires together before starting your tests to see if there is any zero offset in the meter.
The door must be closed.
At the control board check from P9-1 to P8-4. This should be a couple ohms re:the run and start windings of the motor.
then check from P9-1 to P8-5. This should be infinite ohms.
If not then the centrifugal switch 5M/6M is closed. Could be that it's contacts are welded together. Therefore the start winding is not in circuit and the motor will just sit there and hum.
If the above is OK.
Then check the motor windings, see Test 2 in the tech sheet.
You will need a multimeter also some experience working with electricity.
240 volts is very dangerous.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
#5 Posted : Saturday, May 4, 2013 3:41:27 AM(UTC)
Looks like the tech sheet did not attach to the previous post.
I tried it again but it will not attach, could be it is too large.
So I have uploaded it to the following site
Download WED5500.pdf
Un-click the "use our download manager" option, as this may install software on your computer that you do not want.
Then use the gray DOWNLOAD button to get the file.
Note that you may find a copy of the tech sheet in the control panel of the unit.
kclcpa
#6 Posted : Saturday, May 4, 2013 8:45:40 AM(UTC)
kclcpa
Thanks for all that, about to get started, if the centrifugal switch is welded together can i just replace it?
kclcpa
#7 Posted : Saturday, May 4, 2013 9:02:25 AM(UTC)
kclcpa
I found that one of the two wires from the terminal ends of the heating element is broken/separated, this wouldn't keep the motor from running on this model would it?
kclcpa
#8 Posted : Saturday, May 4, 2013 9:12:38 AM(UTC)
kclcpa
Ok, the dryer works if i give a push on the drum while holding start, i can then let go of the start button and it keeps running
#9 Posted : Saturday, May 4, 2013 5:29:42 PM(UTC)
Sounds like the motor is toast.
If it is a centrifugal problem or a motor problem you still havee to replace the motor as they are one assembly.
Part number: AP3094233
Click on the picture for more info.
Also if you decide to replace it try to get the blower wheel off before ordering anything. It is reverse thread. Often it is seized onto the motpor and has to be destroyed to get it off.
