karlkauai
#1 Posted : Thursday, July 19, 2007 5:12:58 PM(UTC)
karlkauai
Maytag Neptune dryper won't stay powered up after the power switch is pushed. It will however stay on after several times. Sounds like a relay in the left side of machine won't stay energized. Get's Error code PF, if you push the switch only once. What is the problem and what parts do I need to fix it.
Thanks,
Karl B Frederick
#2 Posted : Thursday, July 19, 2007 9:00:47 PM(UTC)
Karl
Most likely the problem with your dryer is a bad control board. It is not repairable and has to be replaced. The part number for the new control board is AP3882440 and you can buy it for $145.49.
The breakdown diagrams for the Maytag dryer with the model number MDG5500AWW you can find here: Model MDG5500AWW
If you need the complete step by step instructions how to replace the control board I'll be glad to help you.
Good luck.
jdappl07
#3 Posted : Sunday, December 9, 2007 2:49:23 PM(UTC)
jdappl07
first i would check the power wires at the teminal block where you screwed the cord to make sure the screws are tught after you unplug it of couse
Guest (4)
