Will control panel part no. ap4095433 blk. fix this problem.
Here are your parts Replacement parts for JENN-AIR JJW8530BAB | AppliancePartsPros.comWill control panel part no. ap4095433 blk. fix this problem. No You need Item 3 in the "Control parts" section Cntrl-elec AP4089341. This has the display on it. In almost all cases it will solve the dim display problem. The electrolytic capacitors on the board dry out over time so they cannot hold a proper charge and this dims the display. |
THIS FORUM IS DEAD!!!!!!! |
You need part # AP4089341 for your model number.
Originally Posted by: denman  Here are your parts Replacement parts for JENN-AIR JJW8530BAB | AppliancePartsPros.comWill control panel part no. ap4095433 blk. fix this problem. No You need Item 3 in the "Control parts" section Cntrl-elec AP4089341. This has the display on it. In almost all cases it will solve the dim display problem. The electrolytic capacitors on the board dry out over time so they cannot hold a proper charge and this dims the display. Thank you denman. My Jenn-Air oven which had a dim or no read out is now repaired. When Momma is happy everyone is happy!
