JonnyP
#1 Posted : Monday, April 29, 2013 3:35:09 PM(UTC)
JonnyP
I turn the dial for the timer and click the start button and nothing happens. I know I have power because the light is on when I open the door. There is no buzzing sound, no humming, nothing. Can I assume the start button has gone faulty and needs to be replaced? If so what part would I need and how do I replace it?
Any help is greatly appreciated!
#2 Posted : Tuesday, April 30, 2013 5:50:25 AM(UTC)
I cannot find any info on the given model number.
If this was bought from Sears then you are probably missing the first 3 digits.
Sears/Kenmore model numbers are usually 3 digits, a period and then and additional 6 to 8 digits.
[COLOR="Blue"]Can I assume the start button has gone faulty and needs to be replaced?[/COLOR]
No.
JonnyP
#3 Posted : Tuesday, April 30, 2013 8:24:39 AM(UTC)
JonnyP
I apoligize. It's actually a ken more dryer and the first three digits are 110.
#4 Posted : Wednesday, May 1, 2013 2:57:07 AM(UTC)
Parts for Kenmore Dryer 11066712694 - AppliancePartsPros.com
The most likely culprit is the thermal fuse. This is mountedon the blower housing.
it is the third item on the first row in the parts.
If you go to the Sears parts site they have actual parts breakdowns.
Unfortunately they do not like to share theses with other vendors.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
