2 Pages<12
#11 Posted : Friday, April 26, 2013 4:43:10 AM(UTC)
Good, so you have no refrigeration problems. I would replace the control board, only thing left that would cause this problem.
mazda
#12 Posted : Friday, April 26, 2013 5:32:43 PM(UTC)
mazda
OK thanks, but I see 3 different control boards listed in your parts when I put in KSRA251LSS13, 8201658,8201664 or 8201657? Which to order, don't want to be sent the wrong one.
#13 Posted : Saturday, April 27, 2013 12:23:54 AM(UTC)
Get your serial # and call this parts site, may have a production change requiring the serial # to straighten it out.
mazda
#14 Posted : Saturday, May 4, 2013 12:23:32 PM(UTC)
mazda
Ok, finally got the control board and installed, but still does the same thing, shut fridge off, then turn back on, diffuser snaps open, then slowly closes back up, allows no air through from freezer. I'm at a loss.
#15 Posted : Sunday, May 5, 2013 1:04:24 AM(UTC)
Rather rare, but it might be a bad damper door assembly.
mazda
#16 Posted : Sunday, May 5, 2013 10:05:42 AM(UTC)
mazda
As I said, diffuser snaps wide open, working well when fridge first turned on, then slowly closes up in about 5 seconds and stays closed, is there someway of testing it because it does appear to be functioning, unfortunately already $230 in the hole replacing the thermistor and control board, or is this the only thing left that it could be, and yes I appreciate your effort trying to diagnose this thing over the internet which is tough to do.
#17 Posted : Sunday, May 5, 2013 11:09:23 AM(UTC)
This is an on/off control system in this fridg, anything else would require sensors on the damper motor. Suspect either a voltage leakage path to the damper motor or just a bad motor electrically, or mechanically. Might want to remove it and check.
Preluder
#18 Posted : Thursday, December 1, 2016 4:23:29 PM(UTC)
Preluder
I have the exact same issue with my Kitchenaid fridge KSRA25KKSS right now. Did the OP (Mazada) figure out the issue and end up replacing the damper?
Guest (4)
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
LG fridge not cooling - freezer and ice maker fine - doesn’t look to be defrost related either (Refrigerator & Freezer Repair)
by Guest 7/25/2022 6:04:54 PM(UTC)
Kenmore Elite Fridge Not Cooling or Defrosting (Refrigerator & Freezer Repair)
by ktd.ajd 8/15/2020 6:47:12 PM(UTC)
fridge not cooling good (Refrigerator & Freezer Repair)
by corvairbob 7/27/2020 2:46:12 PM(UTC)
33 year old GE fridge not cooling (Refrigerator & Freezer Repair)
by stevebass 7/11/2020 4:05:50 PM(UTC)
Fridge not cooling enough, but Freezer is fine (Refrigerator & Freezer Repair)
by corriganama 8/19/2019 10:48:58 AM(UTC)
LG LMXC23467D fridge not cooling (Refrigerator & Freezer Repair)
by trkinspector 7/26/2019 6:28:02 PM(UTC)
LG fridge LFC23760ST freezer not freezing, now fridge not cooling (Refrigerator & Freezer Repair)
by blairm 1/20/2019 1:40:44 AM(UTC)
Samsung RF263 Fridge Not Cooling (Refrigerator & Freezer Repair)
by Deke1 6/15/2018 4:05:20 PM(UTC)
Maytag French door fridge not cooling down (Refrigerator & Freezer Repair)
by Sworddylan 10/8/2017 6:50:20 PM(UTC)
Fridge not cooling, freezer is cold (Refrigerator & Freezer Repair)
by ashtong63 9/28/2017 7:22:18 PM(UTC)
by richardwilliamsfaia 4/30/2017 11:14:36 AM(UTC)
Fridge not cooling. No frost on coils. (Refrigerator & Freezer Repair)
by miketh2005 2/20/2017 3:24:09 PM(UTC)
Haier fridge not cooling (Refrigerator & Freezer Repair)
by GraceC 11/1/2016 12:11:48 PM(UTC)
Bevearge Fridge not Cooling (Refrigerator & Freezer Repair)
by abenb 9/10/2016 3:37:47 PM(UTC)
2 Pages<12
