Oahu Kevin
#1 Posted : Monday, February 25, 2013 2:47:02 PM(UTC)
Oahu Kevin
My dryer shows fault code 25 when put into diagnostics mode. As per the troubleshooting instructions that came with the dryer, I bought new inlet and outlet thermistors. When I checked out both old and new using a Ohmmeter, the readings pretty much matched. The next step in troubleshooting says to replace the "Machine Control Electronics". There are 2 "CNTRL Elecs" in the dryer. Can you tell me which one is the correct one?
#2 Posted : Tuesday, February 26, 2013 2:09:25 PM(UTC)
Hello,
This board is located under the top panel on the left side and is shown as #53 at the diagram.
- The machine control electronics Part number: W10110641
Oahu Kevin
#3 Posted : Wednesday, February 27, 2013 11:26:13 AM(UTC)
Oahu Kevin
Thanks for the info.
#4 Posted : Wednesday, February 27, 2013 8:28:52 PM(UTC)
Oahu Kevin
#5 Posted : Friday, April 26, 2013 2:41:04 PM(UTC)
Oahu Kevin
Hello,
Gene, thanks for the reply and sorry I am so long in getting back to this. Replacing the board resolved the fault code. I think there is still a problem with the dryer though, as sometimes the clothes will not be completely dry when the dryer stops, and sometimes it will hover at 7-10 minutes for quite a while and the clothes will be bone dry. It passes the moisture test described by the troubleshooting instructions, but still it doesn't seem quite right. Any ideas?
#6 Posted : Friday, April 26, 2013 3:27:47 PM(UTC)
Hello,
Make sure the dryer vent is absolutely clean all the way to the vent hood as well as all air ducts inside the dryer.
