2 Pages12>
mazda
#1 Posted : Wednesday, April 24, 2013 8:49:24 AM(UTC)
mazda
fridge not very cool even when temp set low, freezer normal, air coming from diffuser is very low, but, shut fridge off, turn back on, lots of cold air for 5 seconds then it slows down even with door closed, thermistor maybe?
#2 Posted : Wednesday, April 24, 2013 11:55:15 AM(UTC)
Remove freezer back panel and check for heavy frost on the coils or in the air returns.
mazda
#3 Posted : Wednesday, April 24, 2013 12:13:50 PM(UTC)
mazda
only very slight frost on coils, air return, thanks
#4 Posted : Wednesday, April 24, 2013 1:51:28 PM(UTC)
If you have a motor controlled damper door, jam a wad of duck tape in the opening to keep the door half way open. Measure the freezer and fridg temperatures after a period of time, should be around zero for freezer, 41 for fridg. If ok, replace the fresh food thermistor. It might be in the damper door harness.
mazda
#5 Posted : Wednesday, April 24, 2013 5:06:37 PM(UTC)
mazda
Ok, will try tomorrow when home, like I said previously, when fridge shutoff then turned back on blows like a mother for about 5 sec then slows to almost nil, will try to find fresh food thermistor didn't see anything like it when cover off will take another look and let you know tomorrow, thanks for everything
mazda
#6 Posted : Thursday, April 25, 2013 11:55:15 AM(UTC)
mazda
turned fridge off, when pushed button and turned back on diffuser snaps open then slowly closed, tried to put popsicle stick to hold open and crushed it. so took it right out, fridge icey cold this afternoon, so I assume thermistor not telling it to open up, am I correct? or could be temp control board?
#7 Posted : Thursday, April 25, 2013 12:45:35 PM(UTC)
If freezer temperature near zero, you most probably have a bad fridg thermistor in the fresh food section, a thin, white, plastic item.
mazda
#8 Posted : Thursday, April 25, 2013 1:21:22 PM(UTC)
mazda
New fresh food thermistor installed, turned fridge on, diffuser snaps open, then slowly closed up completely again, not allowing any air through, as before, what to check next? thanks
#9 Posted : Thursday, April 25, 2013 3:19:02 PM(UTC)
Measure the stabilized freezer temperature and post.
mazda
#10 Posted : Friday, April 26, 2013 4:08:14 AM(UTC)
mazda
freezer set at 2 degrees, thermometer placed inside for 20 min showing 6 and still dropping
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
LG fridge not cooling - freezer and ice maker fine - doesn’t look to be defrost related either (Refrigerator & Freezer Repair)
by Guest 7/25/2022 6:04:54 PM(UTC)
Kenmore Elite Fridge Not Cooling or Defrosting (Refrigerator & Freezer Repair)
by ktd.ajd 8/15/2020 6:47:12 PM(UTC)
fridge not cooling good (Refrigerator & Freezer Repair)
by corvairbob 7/27/2020 2:46:12 PM(UTC)
33 year old GE fridge not cooling (Refrigerator & Freezer Repair)
by stevebass 7/11/2020 4:05:50 PM(UTC)
Fridge not cooling enough, but Freezer is fine (Refrigerator & Freezer Repair)
by corriganama 8/19/2019 10:48:58 AM(UTC)
LG LMXC23467D fridge not cooling (Refrigerator & Freezer Repair)
by trkinspector 7/26/2019 6:28:02 PM(UTC)
LG fridge LFC23760ST freezer not freezing, now fridge not cooling (Refrigerator & Freezer Repair)
by blairm 1/20/2019 1:40:44 AM(UTC)
Samsung RF263 Fridge Not Cooling (Refrigerator & Freezer Repair)
by Deke1 6/15/2018 4:05:20 PM(UTC)
Maytag French door fridge not cooling down (Refrigerator & Freezer Repair)
by Sworddylan 10/8/2017 6:50:20 PM(UTC)
Fridge not cooling, freezer is cold (Refrigerator & Freezer Repair)
by ashtong63 9/28/2017 7:22:18 PM(UTC)
by richardwilliamsfaia 4/30/2017 11:14:36 AM(UTC)
Fridge not cooling. No frost on coils. (Refrigerator & Freezer Repair)
by miketh2005 2/20/2017 3:24:09 PM(UTC)
Haier fridge not cooling (Refrigerator & Freezer Repair)
by GraceC 11/1/2016 12:11:48 PM(UTC)
Bevearge Fridge not Cooling (Refrigerator & Freezer Repair)
by abenb 9/10/2016 3:37:47 PM(UTC)
2 Pages12>
