JJAAYYFF
#1 Posted : Tuesday, April 21, 2009 10:32:31 AM(UTC)
JJAAYYFF
The dryer will run with no heat. The igniter lights for 15 seconds then shuts off without producing a flame. The Hi temp cut off and flame detector check out OK. It was suggested that I check the Gas Valve coils. The coil with 2 contacts measures a resitance of 1300 ohms. The coil with 3 contacts measures 1300 ohms across the 1st and second contacts but infinity on the third. Is this normal? If so what would be the next component to check?
#2 Posted : Tuesday, April 21, 2009 1:51:57 PM(UTC)
Looks like the coils are bad. The correction is to replace them.
- The part number for the coil kit is AP3094251
Here are the breakdown diagrams and Replacement parts for MAYTAG LDG8200AAW | AppliancePartsPros.com
JJAAYYFF
#3 Posted : Tuesday, April 21, 2009 6:09:10 PM(UTC)
JJAAYYFF
Thanks, Gene. I went ahead and replaced the coils and that did solve the problem.
Jay
#4 Posted : Wednesday, April 22, 2009 1:28:36 PM(UTC)
You are welcome, Jay. I'm glad you were able to fix it.
