MJErc
#1 Posted : Wednesday, April 17, 2013 4:56:44 PM(UTC)
MJErc
My Maytag dryer has quit working. I checked the usual suspects (outlet, breakers, etc) and no go! The timer is ticking, but the interior light is not on and it will not turn on. I have recently replaced the heater coil and thermostat and it was working great, until now. Thanks.
MJErc
#2 Posted : Wednesday, April 17, 2013 4:58:16 PM(UTC)
MJErc
I've read it could be the thermal fuse, but I haven't checked that yet.
#3 Posted : Thursday, April 18, 2013 2:05:37 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Maytag PYET344AYW Dryer - AppliancePartsPros.com
Note that RED 4 at the MOTOR CENTrifugal SWITCH goes to L2.
The wiring diagram is missing this.
How did you check the power?
The reason I ask is that the light and the timer are on the same side of the line (Neutral to L1) but it sounds like the timer is getting power.
Neither should work if the thermal fuse is blown.
MJErc
#4 Posted : Thursday, April 18, 2013 4:27:13 PM(UTC)
MJErc
It's a new house so I had the electrician that wired the house check the outlet. He said it was good to go. Do you have any idea what it could be?
#5 Posted : Friday, April 19, 2013 1:19:39 AM(UTC)
Not really because your symptoms do not make sense re: timer works but interior light does not.
You will need a multimeter to trouble shoot this.
Also experience with electrical would be good as the first thing to do is check the interior light. Just in case it is burned out and giving misleading symptoms.
Next would be to re-check power at the receptacle and then at the terminal strip in the unit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
MJErc
#6 Posted : Friday, April 19, 2013 4:22:00 AM(UTC)
MJErc
Thanks. I'll give it a try.
MJErc
#7 Posted : Friday, April 19, 2013 1:14:15 PM(UTC)
MJErc
It turned out to be the thermal fuse. Replaced it and it's working again. Thanks.
Guest (4)
Maytag Dryer Issue (Dryer Repair)
by Erik42 11/7/2017 4:19:03 PM(UTC)
Maytag Dryer issues (Dryer Repair)
by jpstuhr 5/27/2011 7:52:45 AM(UTC)
