Janjan79
#1 Posted : Wednesday, April 17, 2013 4:28:14 PM(UTC)
Janjan79
Oven said "fault detected", had repair person change oven sensor, fault detected again. Oven was way too hot (runaway temp). Told to change control board and I did. Now with a new sensor and new board, I still have an oven that overheats and when I set it to 400f it jumps to 500+ and I have to turn off the oven. Any advice? Much appreciated!:eek:
I used a digital thermometer hanging in the middle of the oven, not touching anything, to check the temperature as it heated. The board was not telling me the correct temp. When I shut it off and set it for a new temp it showed me a different oven temp than it did before.
Simon / APP Team
#2 Posted : Wednesday, April 17, 2013 5:33:13 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to check the wiring and connector between the control board and oven sensor.
Trace the sensor's wires to the control and use a multimeter to check it's resistance at the control plug.
At room temperature you should read about 1100 ohms.
Post the results.
Simon.
Janjan79
#3 Posted : Wednesday, April 17, 2013 6:30:36 PM(UTC)
Janjan79
Thank you so much for the reply. Alas, I don't have a multimeter and I know the repairman did check the resistance and it was fine but I don't know if it was just the sensor or the wiring as well.
Simon / APP Team
#4 Posted : Thursday, April 18, 2013 8:13:16 AM(UTC)
Simon / APP Team
Groups: APP Team
This is the only way that I know how to troubleshoot this problem.
You can get a meter for less than $20.
Simon.
Guest (4)
